Heater blower problem
Old Nov 24, 2007 | 01:57 PM
solarant's Avatar
1996 E300D
1996 E300D.
I have a problem with my heater blower, it blows hot air on the passenger side and cold air on the driver side, I thought the problem had to do with the the climate control module as it was stuck on EC mode so I changed it and still the problem persists, any ideas what might be the trouble.
I only have this car a few months so I do not know if there was any thing worked on and left disconnected etc..
Old Nov 24, 2007 | 02:58 PM
ohlord's Avatar
Not
familiar with the 96 D model,so do you have dual climate controls and onboard climate diagnostics
http://www.eclassbenz.com/node/27
if so run the test and post the values and errors.
Could be two things a stuck duo valve or a faulty flap.
stuck on ec mode being that the lamp was lit all the time?Do you have cooling when the a/c is turned on or is it still stuck on ec mode?
ohlord
Old Nov 25, 2007 | 11:26 AM
solarant's Avatar
1996 E300D
ran test... here are the codes
I ran the diagnostic tests and got the following codes
My EC light is stuck on, also when I have the heat on it blows heat on the passenger side and cold air on the driver side so I ran the diagnostic check and got these values.
Can you tell me which of the codes is causing the blower problem and if possible tell me how to fix the other codes.
1............69
2............53
3............58
4............100
5............53
6............129
7............0
8............55
Codes
1E1............234
2E1............235
3E1............241
4E1............419
Which of the error codes would be the problem for the blowing cold on the driver side and warm on the passenger side.
EB ! 419 says it is the electromagnetic compressor clutch, would this cause the problem and if so how do I replace/repair it, any help would be greatly appreciated.
