Accelerator Issues and Check Engine Light PLEASE HELP!
Old Nov 28, 2007 | 03:18 PM
MA AMGE55's Avatar
2001 E55 AMG Benz
Unhappy Accelerator Issues and Check Engine Light PLEASE HELP!
1st my 2001 AMG E55 would shut down after about 5 minutes of runing and the Check Engine light would come on. It would re-start again after a few minutes and not do it again till next time I used it. I could start it a few times and the Check Engine light would go back out. Now when I start it up it runs fine just sitting there but when I press the accelerator down nothing happens then after a few seconds the rpm's wil begin to slowly rise till it reaches the cut off. IT'S NOT A FUEL ISUE. If I press the accelerator down and then start it with the accelerator depressed it will rev upwards the second it starts then imediately drop back down again and be non responsive. The Check Engine light stays on now too. Is there any way to check the code without an OBD2 tester? I can't drive it now. Has anyone had this experience with there car? Any help would be GREATLY APPRECIATED! When sitting there ideling nothing seems wrong at all and when it gradualy accelerates, the same thing, nice and smooth. I know it is not fuel and not electrical and not a dead battery. Maybe a sensor? But which one?
Old Nov 28, 2007 | 05:20 PM
ohlord's Avatar
Where
are you located?Help is on the way.
Old Nov 28, 2007 | 06:51 PM
MA AMGE55's Avatar
2001 E55 AMG Benz
Massachusetts!
Old Nov 28, 2007 | 07:03 PM
ohlord's Avatar
PM'd you
get back with the info
ohlord
Old Nov 28, 2007 | 07:12 PM
MA AMGE55's Avatar
2001 E55 AMG Benz
Smile
Thanks for any help you can offer.
Old Nov 29, 2007 | 04:10 PM
zx11blade's Avatar
2001 E320, 2008 E63 AMG
I would sure like to hear what's up with your car. I hope you post the resolution.
Old Nov 29, 2007 | 11:39 PM
MA AMGE55's Avatar
2001 E55 AMG Benz
I'll be sure I do Neighbor! I had 2 E320's before my E55 a 97 and a 99 .
Check out my cars plate in the Pic. It's a MA plate, I couldn't believe no one had it.
Old Nov 29, 2007 | 11:44 PM
MA AMGE55's Avatar
2001 E55 AMG Benz
I ordered the OBD II tester tonight so I can check the code....
No one has any ideas?
Old Nov 30, 2007 | 09:20 AM
blueC230K's Avatar
2002 W210 M112 | 2021 X247 M270 | 2015 Audi SQ5 | 2015 VW Golf R
I am sorry that I can't help..but I really like your lip spoiler. Where did you get it? Thanks Good luck with the car!
Old Nov 30, 2007 | 10:01 AM
MA AMGE55's Avatar
2001 E55 AMG Benz
ebay, it came painted and all....
Old Dec 16, 2007 | 01:46 PM
MA AMGE55's Avatar
2001 E55 AMG Benz
Got the scanner today!
It took some time but I got the unit today hooked it up and got a code of P0220 .
the generic dtc definitions in the book it came with says TPS Pedal Position sensor/switch B Circuit Malfunction.
Not sure what part that means but it goes along with my problem of stepping on the gas and not getting a proper response. (slowly the rpm's will rise. REAL SLOWLY!)
Any idea what part may be the culprit?
Jeff
Old Dec 16, 2007 | 02:23 PM
whoover's Avatar
'19 E63S sedan
Probably the accelerator pedal unit.
https://mbworld.org/forums/s-class-w220/217436-acceleration-problem.html
By the way, the sender on the 210 is in the engine compartment, not at the accelerator pedal.
http://www.detali.ru/cat/oem_mb2.asp...SGR=015&SGN=01
Old Dec 17, 2007 | 03:50 PM
ohlord's Avatar
Throttle position sensor
it relays the short length of cable travel from the gas pedal to the sensor located just ahead of the brake fluid reserve on the drivers side engine area,turns mechanical energy into a potentiometer voltage to tell the car how much fuel to be fed into the engine.Looks like it is unplugged or faulty.Check all wires to it and since I never had one go bad i cant tell you what values it should be putting out if you back probed it with a multimeter to see if it was doing it's job,easy diy if you find one at autohausaz.com call them or ask online if they can get one,or oempartsdirest or duval motors.
wish I could be of more help on this one.
Old Dec 24, 2007 | 04:17 PM
MA AMGE55's Avatar
2001 E55 AMG Benz
Tps
Well I ordered the TPS and replaced it and the problem is still there. Any Ideas?
Jeff
Old Dec 29, 2007 | 03:55 PM
MA AMGE55's Avatar
2001 E55 AMG Benz
Maf?
Does anyone think this could be as simple as a MAF ?
Old Jan 1, 2008 | 07:52 PM
MA AMGE55's Avatar
2001 E55 AMG Benz
Any Thoughts?
Does anybody have an idea?
Old Jan 4, 2008 | 12:06 AM
MA AMGE55's Avatar
2001 E55 AMG Benz
Solution
Turns out it was a mouse chewed up my wiring harness.
Old Jan 24, 2008 | 05:55 PM
sudozilla's Avatar
01' E55
I have the same year as yours. Hopefully I don't run into the little gremlins that did a number on your harness.
