Quick Question
Old Dec 4, 2007 | 10:26 PM
nsupra's Avatar
Quick Question
Lately I've been doing some research on SEA FOAM and it sounds like a great product. I have a 430 with 80,000 miles on it. It never had any kind of additives mixed with the gas. Basically my question is should i try a can of this stuff or what? Will it do me nothing but good? I read a few threads in the past not to add anything with the gas.
Old Dec 5, 2007 | 06:28 AM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
You don't say where you are but if you have access to Chevron's Techron Concentrate, try a bottle of that. For that matter, Chevron fuel is highly rated and I would begin using it (has Techron in it too). As far as I know, Mercedes only recommends 2 fuel additives, Techron and something you can buy from a dealer.
Old Dec 5, 2007 | 09:46 AM
nsupra's Avatar
Hmm im located in Connecticut. No Chevron gas stations around here.
Old Dec 5, 2007 | 10:38 AM
ohlord's Avatar
They were
making that recommendation a long time ago when the engine was young and pretty,she is still pretty but could use a good age reversal.
Seafoam or techron both do the job.Cleans internals,injectors,and removes moisture.Don't go overboard.Two treatments a year will keep injectors running trouble free.The first treatment I do is with the tank low 1 can and fill it half way,then run it low and refill as normal(never top off) and log the date in your maint log book you keep
then in 6 months treat a full tank to 1 can.Repeat yearly till death do you part or you sell her.
don't treat the oil,mb spec oil do not need anything.
Old Dec 5, 2007 | 12:37 PM
nsupra's Avatar
Alright thanks a lot. I think i may head over to auto zone today or tomorrow and pick up a can. My Gas tank is 3/4 full so ill wait till its 1/4 left to pour some as you recommended. Is this the right can? http://www.autozone.com/selectedZip,.../selectZip.htm just want to make sure.
Old Dec 5, 2007 | 01:43 PM
tirona's Avatar
1997 s320, 1997 e320
my vote for best product would be for bg44k. i was told by a good mb mechanic to add a can of bg44k to a half tank of gas once a year/year and a half and that should do it if using quality gasoline most of the time, but do this right before you plan of changing the oil. advance auto parts sells them for $20 a can, or ebay you can find for $10-15.
Old Dec 5, 2007 | 02:02 PM
ohlord's Avatar
Yup
that be the seafoam.Does the same job as the other stuff at a third the cost.
Old Dec 5, 2007 | 08:16 PM
nsupra's Avatar
Alright Thanks guys for the information.
Old May 31, 2012 | 03:40 PM
kartik's Avatar
E 320
Hi,
My car is 1997 E 320. My a/c is not working. The codes are as follows:-
1.30
2.28
3.34
4.36
5.31
6.62
7.00
8.28
EB1232
EB1459
Can anybody suggest how to fix the a/c.
Old May 31, 2012 | 05:19 PM
Bucs23's Avatar
2001 E320 wagon
Talking Sea Foam rules
I second the good reports on Sea Foam. Just like Ohlord said don't go crazy on it.
Good luck trying to find "good quality gas" on a consistent basis...
Old May 31, 2012 | 05:47 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Originally Posted by kartik
Hi,
1.30
2.28
3.34
4.36
5.31
6.62
7.00
8.28
EB1232
EB1459
Hello and Welcome -
You are posting in the middle of an old thread on engine cleaners. So you are 'hidden' from most readers. I suggest you repost as a new post.
As you can see from #7 you don't have any compressor pressure. It could be a bad compressor or temp/pressure sensor but it's likely to be that you've lost the charge thru a leak. You can confirm with a local A/C tech and have it tested for leaks before recharging. A/C is generally not a DIY project because of the knowledge and special tools necessary.
B 1232 is a sensor issue and
B 1459 is a comm issue
Both could be caused by the compressor not starting.
