Alignment, now more squeak from the steering wheel?
Old Dec 11, 2007 | 12:36 PM
ajent420's Avatar
2002 E320 4MATIC
Had an alignment done last week at the stealer (although after an indie got it wrong two times, I don't mind).
The alignment is good, but now I have way more squak from the steering wheel at low speeds. The squak was an every now and then occurance, but now it is way more pronounced and happens almost all the time.
What would cause that form an alignment? They don't do anything (i.e. remove) with the steering wheel for this procedure do they?
Old Dec 11, 2007 | 07:43 PM
dsmith's Avatar
88 535is, 89 318iT
I doubt it. Get a automotive stethascope and have someone do the turning while you listen. Is it in the column, rack, pump, tie rod ends, ball joints, etc? Should be easy to find.
Old Dec 12, 2007 | 12:15 PM
ajent420's Avatar
2002 E320 4MATIC
Well, I should say that I can tell it's that all-too-common squak from the wheel when turned at low speeds. I was just curious how an alignment would make that happen more offten than it did already.
Old Dec 13, 2007 | 02:40 AM
dsmith's Avatar
88 535is, 89 318iT
unpossible, they would only move the tie rods. so, whatever it is, seems to be getting progressively worse. unless you can pinpoint the noise, we can only guess. my guess is a p/s leak or air in the p/s system. or, do you think the noise is inside the cabin?
Old Dec 13, 2007 | 11:01 PM
livetodrive's Avatar
2001 E-430 4-Matic
The steering wheel squeak is a common problem for the W210s. My dealer greased it several times, and the squeak would come back within a few days. Finally I took it to another dealer and they replaced the steering rack. That solved the problem.
Old Dec 14, 2007 | 11:50 AM
ajent420's Avatar
2002 E320 4MATIC
yeah, it's definitely the problem that needs more grease...it's only at low speeds and sounds like it's coming right from the steering column where your knees hit. Thanks all, I was just wondering if there was something done to the steering column I didn't know about. I didn't think so, but just checking. Hey Livetodrive, did your dealer charge you every time you got greased? And how much was that rack replacment?
Old Dec 14, 2007 | 05:34 PM
2001 E-430 4-Matic
All the work was done under the extended warranty, so there was no charge. I don't know what it would have cost.
Old Dec 15, 2007 | 09:37 AM
Quadcammer's Avatar
96 and 08 911 turbos
steering rack at the dealer is one party you don't want an invitation to.
Its about $2000 for the rack, and labor would probably be about $800.
so basically, get a rebuilt rack for about $400 and have an indy handle the labor.
Old Dec 15, 2007 | 11:53 AM
ProV1's Avatar
MB, BMW
or just turn up the music, save the $$ for a downpayment on the new S63 AMG
Old Dec 15, 2007 | 01:49 PM
Quadcammer's Avatar
or, stop by the dealer for a $12 bottle of lubrizol, which almost entirely eliminated my squeak.
Old Dec 16, 2007 | 05:00 AM
KADE's Avatar
year 2000 model E-320 210 chassis
Oliverk could you elaborate a little more on the lubrizol.......I too have the steering wheel squeak..but it only seems to be during cold weather.
Old Dec 16, 2007 | 10:36 AM
Quadcammer's Avatar
Yup, same way with me. When its warm, all is well. Below 40 and its baby seal clubbing time.
Lubrizol is a powersteering lubricant. It comes in a 50ml bottle from the dealer for about $12. You remove 50ml of power steering fluid from your car (actually doing a fluid change at the same time would probably be a good idea). Then you replace the missing fluid with the lubrizol.
Then you have to turn the steering wheel lock to lock about 25 times.
Initially mine was not much better, but after driving with it for about a week, the squeak is greatly reduced. You can still hear it on occasion but its much easier to ignore.
Old Dec 18, 2007 | 11:33 AM
KADE's Avatar
"Below 40 and its baby seal clubbing time" GOOD ONE But it still didn't completely get rid of the baby seal noise? wonder if we will have to get a new rack eventually to get rid of noise completely?
Old Dec 19, 2007 | 10:21 AM
Quadcammer's Avatar
well, I only drive the car about 5 miles each way during the week, so the rack doesn't have time to get warmed up and start squeaking.
However, I drove to NYC, and made several rounds through the financial district looking for parking (left/right, left/right, about a thousand times, and mostly at slow speeds) and I didn't hear anything. If it is still there, is so minor that its not worth it for me to pull the rack to fix it.
