Reset A while trying to reset B Service B is now Lost!
07 e350 127k 02 320e 124k miles 93 300e 3.2 liter 221,000 previous 89 300e 200,000
I was trying to reset Service B - Finally the question came up _ DO you want to reset - I pressed the R to reset and it confirmed it, only to find out it reset Service A. Now I don't even see any reference to Service B. Did I reset It, I don't think so, How did this happen. Should I be able to see my miles/time I have to each service at any time? How should this happen?
A and B
simple as above,if you completed all the work needed at service B,it means you also did service A.Service A is approx 10000miles or every year and service B is 20,000 miles or every two years.10k(A)20K(A+B)30K(A) 40K (A+B)
when you get to 50K it's time for A service again and it will count down to that on your FSS recall.
Do you have the manual?
http://www.analogstereo.com/pdf/om/m...anual_2002.pdf
Do you have a list of what each service entails? Did you do all the things A and B service require?
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Manual - no
I don't have the right manual and I don't have the list of all the items of the B service. I did the oil/filter along with the air filter.
what is in a service a and service b for the 2002 320e
This should help
mostly checks and fluid changes and easy stuff.
http://www.geocities.com/mymercedesb...e_a_and_b.html
diy's for a lot of it on benzworld.org w210 diy section and mercedesshop.com diy section.
Hope this helps
ohlord
www.autohausaz.com
www.germanstar.net
www.danielsternlighting.com
Hope this helps
www.autohausaz.com
www.germanstar.net
