Cold Winter in NJ with a Meager Heater
I did a search and only came up with testing the A/C but not the heat. Any suggestions as to diagnosing it?
If it taking to long the thermostat may be stuck or you don't have enough coolant in the radiator,or stuck duo valves.
post the values and In the morning I will record my values with a cold engine and again with it warmed up.Been in the mid 30f at night so it will give you a good indication.
ohlord
