Check Engine Light
Old Jan 3, 2008 | 11:57 PM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
Question Check Engine Light
Was idling the car for 2 hrs,,,check engine light came on and re-appears now with no obvious engine problems,,anyone had this happen before??
Old Jan 4, 2008 | 02:22 AM
ohlord's Avatar
A.
not a great idea to idle an engine for two hours.
B.open the gas cap and screw it back on ,while the engine is off.
if code does not clear after several drives,read the codes,you can order a code reader at harbor freight tools #94169 or pick one up if in your area
http://www.harborfreight.com/cpi/ctaf/retail_stores.taf
http://www.harborfreight.com/cpi/cta...emnumber=94169
or some auto parts stores read them for free.Kraggens,autozone,call around.
post the code here and help will appear
Don't worry unless it is a blinking cel you are okay to drive the car.
ohlord
Old Jan 4, 2008 | 12:17 PM
stemags's Avatar
Yeah,,I know,,but was asleep in the car with the heat on in 6 degree weather.Im gonna try the gas cap thing,Im sure your right about driving it because I have no obvious engine issues since the light came on.Thanks much OL,,I'll post the results with codes if nec.
Old Jan 4, 2008 | 12:38 PM
ohlord's Avatar
Shut
it down for periods of time and use the rest function.It uses the aux pump to send residual heat from the engine into the climate control system for about 30 minutes,and then you warm up again and repeat.
ohlord
Old Jan 4, 2008 | 02:20 PM
stemags's Avatar
LOL,,,been using rest quite a bit,,,sometimes it results in no start at all.Have a jumper/tire inflator in the trunk for those times,,,the battery is a new Interstate 850 cca.But tried the cap,,no good.Ill watch the mileage and engine behavior a while.
