Side mirror problems!
Old Jan 11, 2008 | 07:47 PM
stan23's Avatar
2001 Porsche 911 C4
Hi all,
First post, but reading a lot and you guys have a great community here!
I have a '97 E420, and the side mirrors don't seem to work right. Anyways, if you try to adjust them via the knob, the motor on the mirrors only seem to go down, but not up, or left/right. Meaning, if I move the knob up or left, the mirror points down! I have the same problem on both mirrors. Is it the switch that went bad, or is it the motor in the mirrors? If it indeed is the switch, I hear you need to order the whole console. Is there any way I can confirm or if you know somewhere to buy a used switch.
Thanks in Advance!
Oh, almost forgot, one of the bulbs seems to have burned out on the gauge cluster - actually, it seems to go on and off intermittently, is this something easy to fix? I read that the cluster just 'pops' right out, is that right? Where Do I get a replacement bulb?
Old Jan 11, 2008 | 08:15 PM
ohlord's Avatar
cluster
removal on benzworld.org w210 section,buy the hooks from the dealer or make them or recently saw a member use a suction cup to affix the plastic and gently pull the unit out.
bulbs at dealer or autohausaz.com
not familiar with the 420 mirror setup but if like this, check the wires.
http://w210.pietrzyk.net/disassembly_interior.htm
something seems to be disconnected.
Old Jan 11, 2008 | 08:32 PM
E-Klasse's Avatar
W205 C300
If if is the same for both mirrors then it would look like the switch module needs to be replaced. It is all one unit with the mirror controls and window switches. The module changed in 98 so you will have to find one from a 96 or 97 E-Class or C-Class. I might have a used one if you are interested in buying it cheap to try it out.
Old Jan 14, 2008 | 07:57 PM
stan23's Avatar
2001 Porsche 911 C4
Hi E-Klasse,
I would love to buy out the module and give it a check. Please let me know how we can proceed.
Thanks!
Old Mar 30, 2012 | 11:53 PM
ssscud's Avatar
2004 c230K 1996 E420
Smile adding to the thread
mine doesnt work either -
http://www.edsoto.com/e320/w210/disa...y_interior.htm
anyone have a clue as to how to get parts?
http://www.edsoto.com/e320/w210/disassembly.htm
Thank you greatly in advance,
Old Mar 31, 2012 | 12:20 AM
raymond g-'s Avatar
99 E320
it's not clear what isn't working so you'll need to be more specific. the links
in your post aren't related to mirrors. hard to determine how to help
