Automatic Transmission question
Old Jan 15, 2008 | 06:19 PM
KKSPEED's Avatar
2007 E-350 4-Matic with Sport Suspension
I planned on helping my friend service the transmission on his 98 E300 TD.
The problem is that he replaced the radiator and lost some transmission fluid before I could measure it with my Mercedes dipstick.
I planned on measuring the fluid level with the dipstick before draining it and measuring how much fluid was drained out to know how much to put back in.
Since fluid was lost, I don't know where the full mark is now.
How do figure out how much fluid to put back in after draining and changing the filter?
Old Jan 15, 2008 | 06:56 PM
ohlord's Avatar
Slowly
add and measure.Isn't your special dip stick(You need the special order dip stick) marked with indicators?
Diy on http://www.benzworld.org/forums/w210...1-06-08-a.html
http://www.benzworld.org/forums/atta...-change-98.jpg
Drain the tq converter and use the mb spec fluid.Autohausaz.com Measure at op temp in specs.
When changing filter never use a rag or anything to wipe down the pan or any internal parts,these trans are very sensitive to lint.
have fun,work safe.
Old Jan 15, 2008 | 09:58 PM
KKSPEED's Avatar
He had the dealer check the fluid level the last it was dealer serviced, so I know the level was correct (no leaks located).
Since my dipstick is extra long, I was just going to measure the level with the car hot and mark on the stick where it stops at the top if the dipstick tube.
Old Jan 15, 2008 | 10:25 PM
ohlord's Avatar
80c
level between 54 and 65mm at 80c.if you don't have marks.I have a 722.6 stick if you need one 40 bucks delivered.
ohlord
