2000 E320 Headlight Aim Question
Bob
headlight lens is cut/fluted to aim and focus the beam?) if so, then adjusting
for rotation is problematic as there is no control adj for that axis. if you have
a projector based headlight system, you may need to open the headlight and
rotate the projector on axis. this will be a bit of a custom tweak as there
does not exist a rotational adjustment otherwise.
take a picture of the beam against wall and post. it's odd that the beam can
be this far off spec. post pic of your headlight as well. it is OEM reflector,
right?
__/ __/
Oo==oO
www.danielsternlighting.com last longer throw more light.
ohlord
Is this normal?
right?
Is this normal?
Bob
To me yours do look out of focus and rotated to the left (right low, left high)
I am at sea and can't take a pic of mine but maybe some other gracious member will.
