reciever-dryer // OEM or aftermarket???
Old Feb 7, 2008 | 03:31 PM
gflatt's Avatar
1999 e300td
OEM = $94.00
Aftermarket= $21.00
Whats one to think? better yet whats "TWO" to think??
I hate doing thing twice for being cheep.
coming down to I hope, the closing of this AC project.
Old Feb 8, 2008 | 01:06 PM
ohlord's Avatar
Or
$80 v.s. $17 on autohausaz.com
both are o.e. and you need the new hose.
ohlord
Old Feb 11, 2008 | 01:32 PM
gflatt's Avatar
1999 e300td
reciever-dryer
thank again, Basic thought was sense basic A/C concerns have been cleared up with the evap. temp. sensor replace, I'ed get ready for an A/C hi and lo pressure check later, when it warms up, but before things get sweltering hot. It's difficult to get a feel at the current temperatures.
no. 7 of the A/C diagnosis procedure "refrigeration pressure" has been from
01 to 16 depending on outside temp. I was of an opinion that the low side would be at least 40.
Just looking to be prepared. The final diagnosis didn't give any recommendations.
Old Feb 11, 2008 | 01:36 PM
gflatt's Avatar
1999 e300td
new hose?
what new hose? and to ask, what oil
Old Feb 11, 2008 | 02:18 PM
ohlord's Avatar
Hose
part number on autohausaz.com link with the rec drier"(see note)always a good idea to replace the hose to avoid contamination of the system.and they might have changed the fittings on the new driers.
Have a pro charge the system.
#7 in a good system will vary on demand from about 7-18 or so,it is a variable by demand system so you can see it go up or down in value according to current demand.
good luck
ohlord
http://www.autohausaz.com/search/pro...er/Accumulator
Old Feb 11, 2008 | 03:47 PM
gflatt's Avatar
1999 e300td
the hose
I see it, their recommendation, is that hi side with fittings or low side with clamps? No question pro. job!! about AC oil, any need to be selective? exotic, generic-synthetic?
Old Feb 11, 2008 | 06:13 PM
ohlord's Avatar
Pro
with r134a approved oil.Amount is on the tag up by the ecu and duovalve,tells weight of refrigerant.
ohlord
