Alternator Pulley
I shut down the radio and climate control and limped the car home. Get in the garage and open the hood to see if the belt is still there and find that the WHOLE Alternator pulley is sitting in my engine pan and the belt is wound up good.
Oh for the love of crap, I just had that alternator put in two years ago!!
Luckily this happened less than 3 miles from home after a 6 HOUR drive from DC in this god awful slush storm we are having.
Some times its better to be lucky than good! (ASR saved my *** when I hit a patch of ice in the Baltimore tunnel too, the car twitched to the side and the ASR locked it right down Thankyou MB!)
Soooooooooooooooooooo WTF is up with the Alternator pulley?
I pulled the alternator and fished the pulley out of the pan. Bottom line, burned bearings. I had heard some squeak out of it in the last two weeks when I started the car and assumed the belt was slipping. Bad assumption on my part.
Alt fried?
used aurora auto wrecking seattle
or new ouch
autohausaz.com
ohlord
We'll see what the mechanic says tomorrow.
I went through my service records and the last time anyone fiddled with my Serp belt was the dealership when they replaced my harmonic Balancer. Ain't that a kick in the shins?
Since I had some time today I paid attention. I could not figure out how to marry the Pulley I fished out of the pan to the grooved pulley on the Alternator, and the more I looked at it the less sense it made. There was no damage to the alternator like there should have been if something came flying off it at 2800 rpm
I also fished a washer and nut out of the pan, but NO BOLT.
Went looking through the rest of the engine and found the pix below. Makes more sense, bolt all alone, bent, big gash on the bolt head next to it and a smoke trail on the engine block underneath it.
Belt Tensioner it is. I'm confident this time
Tensioner mechanism was trashed total replacement, when it came flying off, it bashed the water pump pulley so it had to be replaced as well.
Moral of the story? Squeaking belts might actually be pulley bearings going bad, check it out early.
