Brabus Monoblock IV 8Jx17 ET(offset)30 on W/S210
Mercedes-Benz E320 Aventgarde year 2000, Diesel
Hi all
Can anyone confirm that the Brabus Monoblock IV 8Jx17 ET(offset)30 rims with 235/45/17 tires will fit the S210 (wagon) without any wheelspacers or changes to the wheel base?
I know that the standard bolts have to be filled down about 1-2mm, otherwise they intruce on the springs.
Thanks.
Thanks.
41et
is stock,35 is better for wider,30et might be to little.What are they off of?
Where are you located?Don't file lugs....The correct size and ball seat can be purchased from radusa.Tirerack one of our sponsors can be consulted as to fitment issues.They are down in the tire and wheel section.
ohlord
ohlord
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Thanks for the fast reply. The rims and tires are completely new.
In my MB manual for the car, it says that ET37 is stock, not 41. ET41 is stock for 16" rims i think, ET37 for 17".
Great about the bolts, ill try and get them premade. I dont like the notion of filing existing bolts atall.
Im located in Europe.
Correct on the
37 et with 17's.
30's though should take some test fitting to be sure.
I have ordered special bolts from Brabus today, and will have them tomorrow. They say that these rims and the tires are made for this car, and doesnt need any center rings or spacers. Only the special bolts.
Gonna post the result tomorrow, after ive installed them.
7½x17 et41 were (from memory) stock on my W124 AMG E36 estate (wagon to you American folks!
) I fitted a set of four 8x18 et 31 rims to that car - the rears fitted perfectly, the fronts sat a little wide (et 35 would have been spot on).
The 8x18 et31 rims were the stock rims fitted all round on the W210 E36 (saloon only), and standard on the front of the W210 E55 (saloon or estate).
Hope this helps.
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
Hope this helps.
