Interior and unlock flashing light problem
All of a sudden, on my 99 e320, the interior lights no longer work when the door opens or closes, also I can not set the interior lights to fade off when the door shuts like I used to, otherwise the lights work fine as they will stay on, but the automatic features do not work. I know how to properly set the auto interior buttons, so Im not asking which button it is, this seems like a basic electrical problem, on other vehicles its usually a fuse, relay, or frayed wire. I have done lots of testing, and I am still frustrated without any answers. At the same time, when I hit the lock button from the smart key, the lights do not flash indicating that the doors are locked, however, the doors lock as normal, just no lights light up as they use to, but when you unlock the doors from the smart key the front and rear lights light up as usual, but still no interior lights lighting up automatically.
I have checked all fuses, batteries in smart key, door pins, and everything is working fine. This is a major headache, and it would cost a mint to have this diagnosed at the dealer. It seems to be a common issue, but with no answers. Does anyone have any suggestions? Has anyone ever dealt with this problem, if so, how did you fix it?
"on the 210 chassis, you will most likely have to take that to the dealership, due to the fact that there are control modules in that circuit and they will need to be tested with a MB SDS computer. Sometimes the entry feature can be disactivated and will need to be turned back on, it can also be a door open switch malfunction, wiring to the control module, the control module itself."
(You didn't say if you tried that? only that "you know how to set the auto interior button")
Hope this may help.If you have tried overhead dome light feature also you might want to post this in the Mercedes tech talk area of the forum...where they have a MB Tech to answer questions.
just curious if you or anyone else might have slammed the seat belt lock in between the door by accident recently. Because i seemed to have a similar problem with my interior lights and blinking outside lights. Mercedes tech came out and fixed it. When i explained the light problems he knew right away what i did. But it costs i believe around $160 to fix.
