1997 E320 need ratremoval under electronics
1997 mercedes e320
![Angry](https://mbworld.org/forums/images/icons/icon8.gif)
Does an experienced![action](https://mbworld.org/forums/images/smilies/action1.gif)
mechanic know how to do this: I need to removal the plastic electronic box, passenger side in motor compartment near firewall. All the electonic boxes are in this plastic case. I can removal all of them except for the one nearest the back of box. This one has large guage wires. A large metal clasp on on side for connector removal. The left side of case has a plastic push release but the lower right part of box seems to have a special catch. How do I release the card-box, and remove the wire connectors. The rat is under or inback of the final plasting holding case. It stinkith and mu wife will kill me if I can't remove it. HELP
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Wait, you have a RAT in your dashboard?
Please god let there be pictures and a backstory here.
1997 Mercedes Benz E420
You should remove the entire housing...
and check the wiring harness. There have been many reports posted in on-line fora of rodents gnawing on the wiring and causing all sorts of issues.
The "aroma" could end up being the least of your problems...
Good luck,
JR
Good luck,
JR
