Alignment with lowered suspension
Old Jan 23, 2008 | 09:07 PM
E320se's Avatar
2002 E320 Special Edition
It doesn't quite make sense the alignment data from Wheel Works in SF Bay Area. Please let me know if I need camber plate/bolt as all 4 wheels camber are out of spec and they did not say anthing.
In fact I want to raise the whole car by 1/2" as it a bit low to my taste. Will this improve the situtation?
File Type: pdf
Old Jan 23, 2008 | 09:28 PM
dsmith's Avatar
88 535is, 89 318iT
If your car is lowered, then those specs look about right, and not extreme at all. Raising it should decrease negative camber. If it were mine, I would leave it for the handling benefits. It you don't drive that hard and are more concerned with tire wear, then decrease the negative camber.
You could also install camber kits, but if you want to raise it anyway, that would be a waste of money.
David
Old Jan 24, 2008 | 04:14 PM
E320se's Avatar
Thanks for the confirmation as I have a lowered suspension (Carlsson or H&R+Bilstein Sport - photos in my signature) and tire wear is pretty even from inside to outside but going down to wear indicator too fast with Ealge F1 GS-D3 (~15k miles).
I plan to try the Eagle F1 All Season for longer treadwear trading off in bit in handling 'cause just too costly. I may raise it up a bit as it is an issue occassionally at parking lot entrance and speed bump.
Anyone has good input on tires?
Old Jan 24, 2008 | 04:36 PM
ohlord's Avatar
.5
- camber is about ideal for that set up.Anymore and are you seeing increased wear on the inner thread?
Old Jan 24, 2008 | 08:46 PM
dsmith's Avatar
88 535is, 89 318iT
I would be very happy with 15k on tires with those camber settings. If you go with a harder tread compound it's like losing the cornering advantage from the camber. Sounds like you just need to raise it/change it, if cost is an issue and you don't care about the performance advantage.
Old Jan 25, 2008 | 01:00 PM
TonyC's Avatar
e63 p30 estate
to extend tire life, you can always ask the tire shop to FLIP the tires inside-out/left-to-right after every 10K mi.. have to do this on the rear of the s2k due to neg camber...
Old Feb 19, 2008 | 02:57 PM
E320se's Avatar
Just changed to Goodyear F1 All Seasons (A/S) and couldn't be happier. It is probably a bit off from F1 GS-D3 in dry and wet. Let's keep the finger crossed to see how long they will last. The A/S is UTQG rated at 420 while GS-D3 at 280.
Tomorrow I will be visiting a local shop to have a look in raising the car by perhaps 2 spring pad heights as it is sometimes inconvenience. Hope this will also put the camber back in spec. It's approx 0.4deg off in the front and 0.3deg off in the rear. Any comment?
File Type: pdf
Old Feb 19, 2008 | 04:09 PM
ohlord's Avatar
Every
half inch helps
about .4degrees or about.
Those new GY will help also
Old Feb 19, 2008 | 06:39 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
if you want to raise the car by.5 inspect the spring pads..they will have one to four bumps on them to tell what thickness they are without pulling the pads...4 is the tallest and may work for you
raising the car .5 may correct the negative camber ..if not camber bars will correct any negative rear camber problems
Old Feb 22, 2008 | 08:28 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
it looks normal for the set up you have, but for peace of mine get a second opinion on another shop
Old Feb 23, 2008 | 06:51 PM
michakaveli's Avatar
E300
If you don't have the updated front camber bolts, then the bolts may slightly help w/ the negative front camber.
The camber on the rears is impressive in comparison to my '97 that isn't as low as yours. The camber on my rear is -1.7. I've purchased some custom made camber arms to correct this issue from a forum member. Haven't installed them yet though..... On yours with the -0.3, that's not bad at all
Old Feb 25, 2008 | 11:50 AM
E320se's Avatar
Brought the car up from original #2 pads to new #4 pads all around. The car has approx 1.5" wheel gap in the front and a bit more in the rear but a lot more user friendly. Don't need to pay too much attention to parking lot and ramps. Ride is less harsher than before and handling is similar except sitting higher.
In terms of alignment, the rears are definitely in spec but the left front at the limit while the right front is -0.2degree off. I would probably leave this as is and monitor as time passes.
P.S. found a friendly local shop and charges a fair 2 hours labor
File Type: pdf
Old Feb 29, 2008 | 12:28 AM
4XFORE's Avatar
1998 E320 / 1992 LandCruiser / Project Car E30, 91, 318I
michakaveli do you wanna sell the rear camber kit to me?
how much did you pay for it? is it from speedybenz?
speedybenz has not reply to me yet. i badly need one.
Old Feb 29, 2008 | 08:46 AM
E300
I never heard from SpeedyBenz either..... I contacted a member here, "Lensolo"
The parts look pretty good. I may be installing my arms this weekend.
Old Feb 29, 2008 | 10:51 AM
4XFORE's Avatar
can you maybe take a picture of the camber kit? i will contact "Lensolo"
Old Feb 29, 2008 | 11:14 AM
E300
Here is a link to photos of the bars.... My units came looking the same
https://mbworld.org/forums/classifieds/190531-wtb-w208-camber-kit.html
Old Feb 29, 2008 | 07:50 PM
4XFORE's Avatar
https://mbworld.org/forums/showthread.php?t=190531
Thank you. I just sent PM to Lensolo.
