Service Recommended by Local Mercedes Specialist
Lower Ball Joints
Lower Control Arm Bushings
Valve Cover Gaskets
Alignment
Transmission Cooling Line
Spark Plugs
Total Price $1200
Does this sound excessive?
Plugs are due at 100 k and if you do them yourself 28 bucks for the 17mm boot tool from me
and 2.69 a plug ngk7090 times 12 from any auto store.A socket wrench some torx bits for 7 bucks a set and a sat morning for you.Easy.Valve cover gaskets,why?They are hardly ever an issue on the m112 and m113 engines.Trans line is it leaking?
most indie shops dont have the proper alignment equip so you might want to check.Do the tires show abnormal wear on the inside or outside?
Will they let you purchase your own parts and they install?They may be wanting to do the alingn if they do the suspension.
www.autohausaz.com for the parts.
ohlord
Valve cover gasket - was leaking on the passenger side. He showed me that and I saw a small amt of oil from underneath. I'm never had as much as a drop on my garage floor and I never need to add oil
Trans line was seeping. He said they can blow off. Hmmm, not likely. I dont thing thats high pressure.
Tires seem to wear ok. I bought new tires 20k ago and they still look new. The last set still had tread but got really loud. These new tires have gotten a little louder then they were new.
Doesnt like you to purchase parts. Claims his markup is 20%
Alignment was due to the suspension work.
The car tracks, steers and rides like new. I dont think I'll do anything right now. Maybe I'll try to torq the valve cover. I'd bet its just loose.
