Sway bar?
Old Mar 30, 2008 | 12:48 PM
Ben'z's Avatar
E320
Smile Sway bar?
Hi,
Does anyone installed H&R sway bar?
How much improvement of handling?
What is the difference?
Thanks for any input!
Ben
Old Mar 30, 2008 | 01:31 PM
ohlord's Avatar
handles
Better at the trade off of ride quality.Have you installed sport shocks and springs to lower it?You will feel every bump.Like the feel of a slot car going around a turn?you might enjoy it.To keep it balanced you need to install both front and rear bars or the eibach kit.
lastly you have a E320,you don't need the extra .2G handling?as the guy says sure you want it,but do you really need it?
Old Mar 30, 2008 | 04:45 PM
dsmith's Avatar
88 535is, 89 318iT
Originally Posted by Ben'z
Hi,
Ben
Have you ever done any suspension tuning? If not, I would guess an E320 is not really the place to start. Doing research on what each part in the suspension does and how changes affect handling would be a good place to start. Then you need to know what you have and where you want to go with the handling.
In general, though, the more you stiffen one end of the car relative to the other, the less grip you will have on the stiffer end.
It's obviously a lot more complicated than that, so if you don't have an idea of what the parts do and what your goals are, you're just wasting money.
Old Mar 31, 2008 | 01:57 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Instead of the H/R sway bars Try the Factory AMG E55 Sway bars...
I Installed a set on my W210 Wagon and they made a HUGE difference on the turns...WITHOUT any NEGATIVE ride trade off...the sway bars are only used on the turns
Old Mar 31, 2008 | 02:14 PM
ohlord's Avatar
Great tip
Mark.Don't you find bumps transmitted to the unloaded wheel?Or is it not noticeable because it's a wagon.
I was looking into the eibach F/R on our wagon and have those specs do you happen to have the dia.of the E55 bars?
Old Mar 31, 2008 | 07:09 PM
zx11blade's Avatar
2001 E320, 2008 E63 AMG
I have the eibach sway bars front and back. They work great! Yes, you only notice them on turns. The car corners real well. I have only noticed a bumpy ride when the rubber sway bar bushings were shot. Then the bars started banging in the mounting brackets. I replaced the rubber bushings with polyurethane ones and the ride is back to great.
Old Apr 1, 2008 | 01:14 PM
Ben'z's Avatar
E320
Thanks, Ohlord!
Yes, I have sport shocks and lower springs installed. I like the better handle, and don't feel the ride quality is bad at all. That is why I am thinking about getting some more improvement.
You are right. I ask myself, do I need it? Will I just waste money?
That's why I asked people's opinion and experience.
Thanks for your input!
Ben
Old Apr 1, 2008 | 01:20 PM
Ben'z's Avatar
E320
Thanks, Mark!
I will consider E55 sway bars.
Ben
Old Apr 1, 2008 | 01:25 PM
Ben'z's Avatar
E320
I didn't find product of sway bar for W210 on Eibach's website. But, I searched again, then, I found some online shops carry them for W210.
Thanks!
