Help Repairing Fault Code/Other Minor Things
Old Apr 3, 2008 | 01:42 AM
Dannbro's Avatar
1999 Mercedes E320
I received fault code P0713, which from what I read is the Transmission Fluid Temperature Sensor Circuit High Input. What is this part, and how/where can I replace or repair it? I've tried searching Google and Ebay to no avail. Also, my rear headrests don't go down with the headrest drop button. Lastly, a whole bunch of things on my center console, (odometer, A/C, Radio, etc.) don't light up anymore. Is it fuses that need to be replaced? Any help is appreciated, thanks.
Old Apr 3, 2008 | 05:08 AM
ohlord's Avatar
Where are you located?
Have you had your transmission fluid and filter changed?
Get back with those replies and we can look into the temp sensor issue.
Have you checked all the fuses for the dash?Can you post a good pic of the lights out issue?Not clear what lights are out,the actual back lighting or the dreaded pixel dead issue.Lots of things to check and some may have simple solutions.
ohlord
Old Apr 5, 2008 | 02:14 PM
Dannbro's Avatar
1999 Mercedes E320
Well, in January, we actually had the whole transmission replaced because the old one was bad. The transmission we had put in was from an E320 that only had 71,000 miles. I will try to post the picture of the lights that are out when it gets darker tonight.
