topping off fuel
Old Apr 3, 2008 | 12:09 PM
fdte320's Avatar
Question topping off fuel
I just filled my 2000 E320 this morning, of course w/ 91 octane. Somehow the pump did not stop and it overflow, topping off the tank. Now the car is hesitant, slow to react if I step on the gas, like being choked. Anybody had this experience? How can I resolve this issue?
Old Apr 3, 2008 | 12:55 PM
dylokjai's Avatar
00_e430_sport
i dont think topping off will give you hesitant. its prolly your mind playing with you lol. i top my fuel off sometime by accident looking at the stupid tv screen they have installed on the pumps now at chevron after that the car feels normal. i actually have to clean off the gas that dripped out to the paint but that about it.
Old Apr 3, 2008 | 01:09 PM
ohlord's Avatar
Never top
off. Use the auto shut off feature and shut it down at the first click.If you get fuel down the overflow vent it can pollute the evap charcoal canister and that will cause problems,codes,poor running,ruin charcoal canister.
Just drive it around today,remove the gas cap tonight and let it sit for about an hour,replace the cap(make sure it is on straight)
No check engine light?
you should be fine
ohlord
Old Apr 3, 2008 | 03:02 PM
fdte320's Avatar
Thanks for the reply guys. It was really overflowing. Gasoline was flowing out of the filler as soon as I remove the pump. I'll try OhLord's advice and will post the result here.
Old Apr 4, 2008 | 03:33 AM
Brookied's Avatar
W210 E200 Komp Auto 2001
stick a hose in a syphen(sp?) off a boat load of fuel from the car.
Old Apr 4, 2008 | 09:11 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Never Top Off A W210
you should be fine
ohlord
Ohlord speaks the truth, never top off a W210. not only will an over fill contaminate the charcoal evaporation canister and cause rough running stumbling and even a stall. An over fill condition can cause the tank to expand to the point when the fuel nozzle is width drawn the fuel can shoot out of the filler neck all over the person fueling the car, bad situation been there done that.
Put the fuel nozzle in the filler neck fully. (in as far as it will go) You can use the auto shutoff lock. When the nozzle clicks off that is it! Don't try to squeeze any more in.
FWIW some cars can be topped off just not Mercedes. My Chevy truck can take 2.5 gal. after it clicks off first time.
Old Apr 4, 2008 | 10:17 AM
Air Marshall Eldritch's Avatar
John Deere
In one sense, you guys are lucky. In NJ (and Oregon), state law forces you to let the attendant handle the pumping, else we'd all blow ourselves up of course.
Even though most everyone pays by credit card these days, the workers still have the mindset up rounding up to the nearest dollar after the auto-shutoff so they don't have to bother both coins. Did I mention we are paying by credit card?
I have to specifically tell them not to do that, every single time.
Old Apr 4, 2008 | 10:59 AM
fdte320's Avatar
Yatch Master is right. That is exactly what happened to me yesterday - rough running, fuel shooting out of the filler and I forgot to mention, it stalled at a signal light. However, it runs fine now. Last night I started the engine, popped up the hood, checked for any leaks or unusual noise, I revved up the engine just to see what happens. When it reached the 4000 rpm, the engine started to shake, runs rough and a little bit of smoke out of the tailpipe. Any advice?? This never happens while driving because I don't reach the 4000 rpm driving. Thanks a lot guys.
Old Apr 4, 2008 | 11:52 AM
ohlord's Avatar
Alert
I don't know how many times i have posted this but besides the top speed limiter Mercedes puts on these cars there is a park rev limiter that kicks in if you rev it up while in park.comes in at around the revs you mention.Cuts the spark to several cylinders and even stores a 0300 multiple cylinder misfire code in the obd2 diagnostics.
solution don't rev it past 3 g in parkNow everybody is going to run out and try it
ohlord
Old Apr 4, 2008 | 01:57 PM
fdte320's Avatar
Thanks for the clarification OhLord. I think very few MB owners know about this park rev limiter, me included. Thanks a lot. BTW, in changing the tranny fluid, I have read in one of these forums about a thermometer to measure the fluid temp. Is this required or can we rely on the dipstick?
Old Apr 4, 2008 | 03:59 PM
ohlord's Avatar
The
dipstick (i sell for $40 has low and high temp lines.You can if you measure what you drain out and replace short of that run the car and measure the level.However a infrared thermo is not that much at
http://www.harborfreight.com/cpi/cta...emnumber=96451
and that is even more accurate.Level is critical and latest info on fill level would make it seem that that is the best method.
ohlord
