Loose Side Mirrors on W210?
Old Apr 3, 2008 | 02:38 PM
robrelish's Avatar
E320 W210
I've got an issue with both my drivers and passenger side mirrors being loose.. when I accelerate my mirrors push with the wind and Im tired of it, is there a fix to getting these mirrors to be more solid.. I feel like they are hanging on by a thread... I guess maybe the spring came loose? how can these be fixed the right way.
Old Apr 3, 2008 | 02:50 PM
ohlord's Avatar
Get in
there and tighten what ever is loose
http://w210.pietrzyk.net/disassembly_88hoodfend.htm
should be obvious when you examine the inner workings of the beast
ohlord
Old Apr 3, 2008 | 11:18 PM
516mbtek's Avatar
'06 CLS55 P030
Correct
The metal part that holds the spring breaks. Either replace the frames....or r&r the mirror assemblies, remove the covers and drill a hole (or use a self-tapping screw) further down on the frame and install about a ~1.5" sheet metal screw which will then be used to hang the spring on again.
