Auto Trans Fluid for '96 E320
Old Apr 21, 2008 | 06:12 PM
BostonC4S's Avatar
'96 E320; 170K miles with extensive rust!
Just checked my ATF dipstick while the engine is warm and it is a bit on the low side; although the color is "perfectly pink". This is the 4-speed unit; what is the proper fluid? The owners manual says to only use "MB fluid". Also, what is the capacity between the "hi" and "lo" marks on the dipstick? Thanks.
Old Apr 21, 2008 | 08:00 PM
ohlord's Avatar
Atf3
atf4 dex3 do not use the fluid made for the 5 speed.Measure at operating temp with engine running.Ever been changed ?probably time.
ohlord
Old Apr 21, 2008 | 08:37 PM
BostonC4S's Avatar
Thanks for the reply. Fluid was changed by Indy about a year ago.
Old Apr 21, 2008 | 09:14 PM
BostonC4S's Avatar
ohlord, just to clarify, the correct fluid is ATF-3?
The Pennzoil site lists the following:
Pennzoil® ATF+3 ATF
Pennzoil® ATF+3 is an automatic transmission fluid designed specifically for automatic transmissions and transaxles used in Chrysler vehicles. It is fully compatible with Pennzoil® 7176 ATF. It is manufactured with specially selected friction modifiers, highly refined base oils and a shear stable viscosity index improver. ATF+3 ATF has excellent oxidation and thermal stability for long mileage component protection.
Old Apr 21, 2008 | 09:38 PM
ohlord's Avatar
Any of the
fluids that is compatible with dex3.The 722.4 trans is very robust and less sensitive to trans issues compared to the 722.6 trans.
ohlord
