(ASR) (ABS) LIGHTS IS ON NEED HELP
1 Post
W124 E320, w210 E420,W210 E55 AMG,W220 S430 (sold),W163 ML 55AMG
When I start the car every think is good no warning lights at all but when I push the brake pedal then (ASR)(ABS) lights coming on and brake lights are not working at all (I test the brake sensor it is good ? I guess ) is any one head some think like that ?
Can any one give me advise what to do .
And can some one tell me what is (display defective and its shoving radiator picture )
All gauges work fine ?????
replace
the brake switch,diy on benzworld.org w210 diy section.Dealer has the upgraded switch.
ohlord
ohlord
2000 E320, 2007 Land Rover LR3 HSE, 2008 E350
sounds like the 'brake light switch/brake switch'; but, try this first... turn your vehicle off and turn your steering wheel from lock-to-lock - usually, this should fix the problem and if not... replace the brake light switch!! it's an easy diy project and the part is less than $25 at the dealership! good luck.
thats
the reset for the steering wheel angle sensor after battery disconnect.If the engine is off the wheel will be locked so how would he turn it lock to lock?the engine needs to be running to center the sensor and with no brake lights the brake switch is the problem anyway.
ohlord
ohlord
1 Post
THENK YOU FOR (ABS ASR ) WARNING LIGHT REPLY
Thank you any way it was fuse problem I replace a tail lights (made In china ) probably short the light socket and blow the fuse so (IF YOU HAVE A (ABS)OR (ASR) WARNING LIGHT DON’T BE SHAMED
TO CHEK THE FUSE FIRST THEN IF ITS NOT A PROBLEM DIG IT UP MORE )
THANK YOU ANY WAY
SO NEXT QUESTION what is the (DISPLAY DIFECTIVE) mean ???
All the gauge cluster work perfect ?????
THATS THE CAR
Attachment 129378Attachment 129382Attachment 129380Attachment 129381Attachment 129383
I LOVE MY MERCEDES AND I NOT THE ONLY ONE
THANK YOU ANY WAY
THATS THE CAR
I own a 1999 W210 Mercedes.
I have a brakelight switch....
-Leo
