AC Re-Charge
Old May 2, 2008 | 03:36 PM
Rossi430's Avatar
'99 E430 & '00 ML430
AC Re-Charge
'99 E430 Needs AC Re-Charge
Is this an easy DIY ... any directions out here.
Old May 2, 2008 | 05:09 PM
ohlord's Avatar
Does
it run?how col does it get?Have you ran the onboard climate control diagnostics?
http://www.eclassbenz.com/node/27
run them ,post the values 1-8 and the errors/
If the system has a leak large enough to require refill,it is better in the long run to have it located and repaired and a new drier installed and refilled properly with the correct weight of r134a and oil.
ohlord
