1997 E-420 - If I put new head unit, will I lose my 6 CD changer?
Old May 3, 2008 | 12:48 AM
hadam's Avatar
2007 S-550, 2001 E-430 & 1997 E-420
I am thinking to put new head unit in my 1997 E-420. The OEM unit is giving me some trouble, specially with election year I like to listen AM channels.
If I buy new head unit and install, can I still use my OEM 6 CD changer in trunk?
Old May 3, 2008 | 01:30 AM
raymond g-'s Avatar
99 E320
well....that would depend on the HU you have in mind, wouldn't it?
Old May 3, 2008 | 01:31 PM
lkchris's Avatar
'10 CL550, '12 GL550
Stick with Becker, that is.
Old May 4, 2008 | 02:26 PM
E-Class Owner's Avatar
1997 Mercedes Benz E420
Your original...
head unit was actually built by Alpine, I believe, and had an "M Bus" connection to the 6 disc changer.
As long as the new head unit is compatible, you should be good to go; however, the loss of AM stations may be due to a "diversity amplifier" on the way out [it is located in the left "C pillar"] as opposed to a bad radio.
Good luck,
JR
Old May 6, 2008 | 11:56 PM
hadam's Avatar
Thanks for all your feed back.
So look like if I change my head unit then I will lose my CD changer. I know my bose amp still work with new head unit.
Old May 14, 2008 | 01:05 AM
h0rn3t920's Avatar
97 E420 W210, 95 Volvo 850 Turbo Wagon
get a head unit that can play mp3 discs. then 1 disc is all u need
