Premium Fuel?????
Old May 20, 2008 | 07:50 PM
benzwannabe's Avatar
I'm looking to buy
Premium Fuel?????
Just purchased my e320 4 matic wagon and I'd like to hear from you all out there who do not use premium fuel and ant pros and cons. Thanks
Old May 20, 2008 | 08:08 PM
ohlord's Avatar
Like
the car?
Use the recommended grade premium fuel.You will have no worries of knock sensors ,burning holes through pistons,read the section in your manual about procedures to follow if forced to use anything other them premium.Do you really want to go around at 2/3 throttle or granny drive up hills?It is a high compression engine it needs high test fuel,you gain back in mpg what you pay out for the 20 cents and your engine won't suffer detonation at the wrong time.
ohlord
Don't even listen to peeps that run regular,they know not what they do,and when they sell their cars,they lack the ***** to say they fed it a steady diet of regular fuel because they know it was the wrong thing to do but were to cheap to admit it.
Old May 20, 2008 | 11:19 PM
benzO320's Avatar
1996 E320
ya wtf am i doing.... gas prices are so high so ive been putting 87... i need to put 93 u can tell a big difference in the way your mercedes drives from throttle response to mpg....
Old May 27, 2008 | 01:04 AM
Z06EATER's Avatar
1997 C36AMG
u fellas better run 91
like ohlord said, do u like ur cars? u will throw a rod if you don't run the right fuel
Old May 27, 2008 | 01:37 AM
4matic's Avatar
04 S430 4Matic/03 Ml 320/ 98' E320 4matic/ 73' slc 450/ 05 cherokee
Post premium
run premium...then there shall be no worries! its not worth throwing regular in...you wont get the performance and problems will definitely derive...my good sirrrr...go premium
Old May 27, 2008 | 08:41 AM
johnnydee's Avatar
C55 R1200R ML500 R320BT
I started to run 87 in my E430 but I started to notice a lot of black smoke in the exhaust!
I decided to go back to 91 and the smoke went away and both the car and I are much happier!
John
Old May 27, 2008 | 08:45 AM
h0rn3t920's Avatar
97 E420 W210, 95 Volvo 850 Turbo Wagon
my parents always ran the car with premium then when they handed the car to me in the first few months of using it i used regular and the car had all sorts of problems. now all i use is premium and it seems to be fine.
Old May 27, 2008 | 04:22 PM
Quadcammer's Avatar
96 and 08 911 turbos
youd be more likely to damage a hyper piston than to throw a rod from some detonation on a mild 220bhp V6.
Old May 27, 2008 | 11:31 PM
GGM's Avatar
GGM
2008 E350
Why would anybody buy a Mercedes and then want to cheap out and put in regular gas? Even with the price differential at $.30 a gallon, that's still less than 10%. You will get at least 10% better mileage using the grade of fuel the manufacturer calls for. I only use premium. I want to get all of the performance my car was designed to deliver.
A seach of the forums for "premium gas" or "regular gas" will find all kinds of discussions on this topic.
I hope this helps.
