One pin or two pin pads?
2001 E320 4-Matic
OK - I know I need to pull a wheel and check, but I need to order parts asap...
2001 e320, 4-matic
Vin: X051070 (last 7)
From what I'm reading..
Buy the two retaining pins version if your VIN is:
A000000 to A379346
Buy the one retaining pin version if your VIN is:
A379347 to xxxxxx
I know this may seem very apparent but want to ask anyway - based on my VIN, I'm assuming I need the one pin version, correct?
2001 e320, 4-matic
A000000 to A379346
A379347 to xxxxxx
just
call autohausaz.com and give them the vin.Do you need new rotors?
tirerack has akebono pads if you want to cut way down on dust.
ohlord
ohlord
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
2001 E320 4-Matic
The VIN is definitely an X in the 11th position. I thought this odd also, but confirmed - not sure what this means in terms of where the car was built...
I am looking to do both rotors and pads.
One more question - does this have wear senors front and back?
Tx for all the help!
2001 E320 4-Matic
Called autohausaz and they were very helpful. This is the list they sent based on my request for oem replacement grade parts:
Front Brake Rotor
210 421 22 12
Brembo/Zimmermann
$65.53
2
Rear Brake Rotor
210 423 06 12
ATE
$40.95
2
Front Brake Pad Set
004 420 03 20
Pagid/Textar
$69.79
1
Rear Brake Pad Set
002 420 52 20
Pagid
$49.98
1
Front Brake Pad Wear Sensor
140 540 12 17
Pex
$1.00
2
Brake Rotor Set Screw
201 421 01 71
Fisher & Plath
$1.03
4
Brake Fluid Dot 4 Low Viscosity; 1 Liter
812 201 42 156
Pentosin
$11.95
1
Front Brake Rotor
210 421 22 12
Brembo/Zimmermann
$65.53
2
Rear Brake Rotor
210 423 06 12
ATE
$40.95
2
Front Brake Pad Set
004 420 03 20
Pagid/Textar
$69.79
1
Rear Brake Pad Set
002 420 52 20
Pagid
$49.98
1
140 540 12 17
Pex
$1.00
2
201 421 01 71
Fisher & Plath
$1.03
4
812 201 42 156
Pentosin
$11.95
1
