Air Conditioning Code coversions
Can you help me with these reading and tell me what they mean?
These are the codes you suggested I get
Please convert and give advise
1997 E320
The readings on my air are as follows
1 - 32
2 - 33
3 - 29
4 - 24
5 - 30
6 - 76
7 - 11
8 - 49
E Code FF Only
Problem cold in one vent warm or hot in the other
1997 E320
1 - 32
2 - 33
3 - 29
4 - 24
5 - 30
6 - 76
7 - 11
8 - 49
E Code FF Only
possibilities at the temp you are at is a little low on r134a,you can put in a can from any auto store and follow the directions on the can.The other is a simple stuck duovalve located up by the pass side firewall in the recess that holds the ecu.Looks like two little beer cans sitting side by side give them a firm tap on the sides with the handle of a screw driver,not to dent them just a good drum like tap.
After doing the above run the tests again and also check for errors again.
diy for duo valve location on benzworld.org w210 diy section.
ohlord
ohlord
It is probally rite in front of me but I can't find the link for DIy when I am logged into the 210 section
the blue stickies at the top of the page ,they never move always on the top greg organized them into different sections to make it easy to find what you are working on.
ohlord
http://www.benzworld.org/forums/w210-e-class/
ohlord
Currently Active Users (1)
