1997 E320 is a heater Valve and a duovalve the same thaing
Since the a/c and heat are a full time demand based system the heater valve is the duo valve.
have your stuck?Diy rebuild on benzworld.org w210 section diy.
or sometimes a tap with the end of a screw driver handle on the sides of the valves frees them up.
ohlord
My mechanic said I had a leak in my heater valve and my low coolent light came on.
I will do a more thorough inspection now that I know it is the same part
I am in Florida - is it ok to top off with only water?
Autohausaz.com may list the two parts.
Always add 50/50 mix of zerex G05 the additives in it are what stops corrision and electrolysis in the aluminum block.How much is it leaking?
ohlord
I have tighten the screws on the valve
They tightened slightly
Put in another quart and will check to see if it goes down again
