How Much $ in Labor ?
Old Jun 16, 2008 | 11:07 AM
Britrover's Avatar
01 W210 E Klasse | 02 W 463 G-Wagen | 06 Land Rover LR3 HSE
Arrow How Much $ in Labor ?
Looking to get the transmission and coolant flushed/changed as my ride has just gone past 90K. How much would be a reasonable amount for this service parts plus labor? The dealer is crazy expensive so I will be calling around some local independent shops.
Old Jun 16, 2008 | 01:18 PM
ohlord's Avatar
no flushed
trans fluid and filter on the 01 mb fluid only.You could diy,same with coolant change.Diy on benzworld and mercedesshop
You are also coming up on plugs pm me if you need the special tools
diy will save you about 900 bucks on the 3 items
"GOT CODES?"
Old Jun 16, 2008 | 01:20 PM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
.8 to 1.2 hours to do both fluid and filter per Alldata.
Old Jun 16, 2008 | 02:17 PM
tirona's Avatar
1997 s320, 1997 e320
i think 1 hour to let the tranny fluid drain is not enough, i would let it drain at least 2-3 hours, maybe even overnight if it looks really dirty. work involved is actually minutes for a mechanic with a lift, time to let it drain is long and fluid is expensive.
