Display/Dash lightbulb
Old Dec 18, 2002 | 05:01 PM
zmirza's Avatar
02 E55
Hello,
My display/Dash where the odometer/MPH display lights are one of them went out. How hard is it to change that. Any help would be greatly appreciated
Thanks in advance
Old Dec 18, 2002 | 10:27 PM
Alpha One's Avatar
1997 E-420 2002 Toyota Land Cruiser
It is easy if you have the Mercedes tool for removing the instrument cluster. Otherwise you will have to gain access to the cluster from below, reach in behind it and push it out. The cluster is a friction fit and comes out with a little tug (or push). The tool is available from SamstagSales.com and I recommend them.
Part Number: 140 589 02 33 00
Mercedes-Benz Instrument Cluster Pull hooks, W , Germany, For the newer cars. 182mm long. Set of 2. $24.99
Old Dec 27, 2002 | 02:03 AM
MBCL500's Avatar
CL500,E320,M3,CORVETTE HARDTOP.
Wink
I did it with a metal coat hanger. cut it and bent it into a little hook
stick it into the side of the dash and pull.
00, 02, 140, 33, 589
