AT Fluid & Filter Change E430
Old Jul 7, 2008 | 07:57 PM
jsaluzzi421's Avatar
1999 E430 Sedan
Folks:
I am starting a new thread as my question was burried in my previous post under A & B Service.
I am contemplating doing this service myself especially since reading the excellent post with pics on this forum.
However, I called the MB Dealer and was quoted $270 for this service. My question is what do you guys think? Is this a fair charge or would you suggest DIY. About how much would it run for parts to DIY?
Thanks and regards.
Joe
Old Jul 7, 2008 | 08:23 PM
mistertonyn's Avatar
1999 E320 & 2008 S550 Designo
I recently had mine done by an Indy shop that charged me around $270
because mine had the torque converter plug which allows more of the old fluid to drain out...so more fluid to replenish...those MB transmission fluid are not cheap.
That price includes a new filter and gasket for the pan of course.
It does not look too hard to do...if you are weekend mechanic..should not be a problem.
It helps to have a lift...makes it much easier to do... and it can get messy so
I just had it done by a professional.
The dealer in my area wanted $400+....I don't think so
Old Jul 8, 2008 | 12:07 AM
ohlord's Avatar
You
have a tq plug if built before sept 99 you could drain about 8 from both trans and tq.
8*15 for 7226 trans fluid from
www.autohausaz.com
filter and gasket
I ship the dipstick and pan magnet pm me for $
and tips and diy info
plus use
www.mercedesshop.com
diy
and I have more info
you can do it.
and you might as well replace the connector for the electrical while down there (it is a problem issue)
that if leaks will cause you to be up the creek.
ohlord
Old Jul 8, 2008 | 01:57 AM
OHLORD..I thought you were donating those dip sticks
to fellow members...
We inspected the connector on my car and it was dry so we did not replace it. It is easy to get to if I need to replace later if I see signs of it starting to get wet with oil.
For some reason mine did not have a magnet in the pan....
Old Jul 8, 2008 | 02:09 AM
TMAllison's Avatar
09' E320
Its not any more difficult than any other trans service and with MB's pan bolt and gasket system you are almost assured of no leaks. Late 98 on all had the updated solenoid seals IIRC.
Use the fluid for the 722.9 trans (#3353), its backward compatible to the 722.6, cheaper and has better friction properties. dealer will use the new fluid when the current supply of old fluid is exhausted. Get the magnet too A 220 271 00 98.
You'll need the factory tool dip stick or the measurements for the business end of it (PM me) and some way (IR thermo) of knowing the internal fluid temp. Current spec is to ignore the 40C end of the stick and ONLY fill to the 80C mark.
Some V8's used more fluid (~9l vs 7.5l) than the 6's did. Check your manual and/or carefully measure what is removed.
Old Jul 8, 2008 | 02:44 AM
ohlord's Avatar
722.6
fluid is 15 bucks at autohausazcom 7229 7 speed fluid is more at the dealer even if it is backwards compatible.
follow my instructions for filling and you need no ir thermo the trans temp is the coolant temp when filled to near capacity and warmed properly.
Fill level is to top of 80c mark reduces aeration and gives better shift quality.
ohlord
do it every 40k miles and the trans will live as long as the engine
Old Jul 8, 2008 | 12:18 PM
TMAllison's Avatar
09' E320
Newer 722.9 fluid was $11L when i purchased recently from Fastlane.
I'll agree there is a relationship between trans fluid temp and coolant temp, but not that they are the same. This is why the trans has an internal fluid temp sensor accessed via SDS.
IMO, lacking a IR thermo and shooting the bottom of the pan, one is better off carefully collecting and measuring drained fluid and replacing with like amount. Assuming no leaks or spills that is fairly accurate and final fill can then be fine tuned using the dip stick to make up the extra couple of ounces retained by the old filter, etc.
Old Jul 8, 2008 | 02:07 PM
ohlord's Avatar
That
is a great price on the 722.9 7speed fluid.Thanks for the tip
Filling to near drained capacity and shifting through the gears while doing so,and then a 15 minute drive and final check to mid point has always worked fine for ones Ive done Follow up the next day with slow top off to top 80c mark.
IR is handy to have you are correct.Besides it comes in handy to check bad cats
The main thing people miss on these trans is to make dead sure no linty rags are used to clean the pan or to wipe anything inside the trans body.An absolute clean dust free lint free area,or the trans can get real bad real quick.
Old Jul 8, 2008 | 04:22 PM
Instead of using a lint free rag...I saw him use a spray can
(some sort of cleaner) to spray the inside of the pan out. Is this method just as good or better?
Old Jul 8, 2008 | 04:47 PM
ohlord's Avatar
Spray cleaner or parts cleaner
but you need to wipe it off,so use lint free cloth.
ohlord
Old Jul 15, 2008 | 02:28 PM
f-rod's Avatar
2020 S560, 2020 SLC43, 2022 RAM Longhorn Limited, 2025 Genesis GV80 Prestige
Opinions on Amsoil products?
http://www.amsoil.com/storefront/atf.aspx
Old Jul 15, 2008 | 04:48 PM
ohlord's Avatar
Don't
use them.
Not mb spec on the trans fluid.Not mb spec on engine oil.Why gamble?
ohlord
