Right side of car is sinking??
Old Jul 14, 2008 | 07:35 PM
bigxclumzy's Avatar
2002 E430
my set up is h&r springs, bilstein shocks, #1 pads all around. had this setup for atleast a year.
my right side of my ride is sinking. started to slowly sink the last two months. used to have a two finger gap between fender and top of tires, now the right side is at a one finger tuck, while the left side is still fine. i have not had the chance to look at the suspension yet. but, before i do is there anything i should look for.
Old Jul 14, 2008 | 07:52 PM
TMAllison's Avatar
09' E320
Originally Posted by bigxclumzy
2002 E430
Spring perch collapse? Is usually a sudden failure though.
Old Jul 14, 2008 | 08:01 PM
ohlord's Avatar
Not an issue
on his year and model
springs take at least 6 months to settle in and take a memory.That is when you play with pads and set final ride height.
inspect your mount to be sure.However i think you will find the spring has just settled in.
ohlord
what pads # are you running and what shocks(sport)?
Old Jul 14, 2008 | 08:26 PM
bigxclumzy's Avatar
#1 all around w/ bilstein sport
Old Aug 22, 2008 | 08:07 AM
bigxclumzy's Avatar
still puzzled. isolated problem to mainly the right rear. is about 3/4 of and inch difference from the left side. swapped springs from left to right and made no difference.
Old Aug 22, 2008 | 11:27 AM
Peter_02AMG's Avatar
07E63, 12E350, 08997TT, 16SiennaSE
H&R pad#1
My H&R didn't drop any at first. All four corner was different height, i once had .5" different in the rear but evenually it level out. Now both side are the same height. It take over a year to drop 1" ft & 1.25" rear.
I noticed it settle faster when I had 5 adult included myself in the car a fews time aweek. You might want to check your tire pressure or what in your trunk. I wouldn't worry about it, it will work it self out
Old Aug 26, 2008 | 02:30 AM
bigxclumzy's Avatar
already swapped springs from the left to the right. same thing.
Old Aug 26, 2008 | 09:53 AM
ohlord's Avatar
One corner
only,get the correct thickness pad.Pad sizes and numbers on benzworld.org w210 section diy,
by raymond g,and install it on the corner that needs it.Won't change spring rate will level car out
if the others settle down you remove the pad and match them up again.
ohlord
