Shaking at idle
Old Jul 15, 2008 | 06:44 PM
NOLA911's Avatar
g500, e500
Shaking at idle
My new to me E320 is shaking pretty rough at idle. Any gas at all and it goes away. It only happens in drive, no problem in neutral.
After a few searches, I have concluded I am going to order engine mounts, but before I rip this sucker apart, has anyone had this problem with an e320 v6?
I found a few people who replaced the mounts on the 430s but no such luck on the 320, and if the effect was similar.
Thanks in advance guys!
Old Jul 15, 2008 | 07:31 PM
ohlord's Avatar
First
scan for codes.Any check engine light?Have you inspected the mounts?Yes v6 reacts the same and if a mount or mounts will respond the same.
www.autohausaz.com for mounts about 60 bucks each.Diy on benzworld.org w210 section.Be safe,work safe,support the car properly.
Answer the above questions before you rip it apart
ohlord
Old Jul 15, 2008 | 07:44 PM
NOLA911's Avatar
g500, e500
oh lord, I appreciate the quick work! I ran the question over at BW also, and I saw the very good writeup.
I looked under the car, the hockey puck looking mounts appear in tact and clean. I do not know if this is the right part though. It is about 4 inches round with metal on top. At 60 dollars each, I will probably replace them anyway, since in the car's 130k miles, I do not recall any time she did it. My dealer wants 140 each!
I have no CEL. Does this car show codes for minor things with the OBD 2 not triggering a CEL?
Old Jul 16, 2008 | 06:34 PM
NOLA911's Avatar
g500, e500
Riddle me this, riddle me that.... Today the car barely shook at all. At some lights it was not noticeable. This is the same tank of gas, the same daily commute. I ordered the motor and transmission mounts anyway.
It seems like they were replaced once already under warranty a long time ago, are the replacement parts as weak as the original?
Old Jul 18, 2008 | 01:16 AM
4XFORE's Avatar
1998 E320 / 1992 LandCruiser / Project Car E30, 91, 318I
check this out
https://mbworld.org/forums/showthrea...78#post2110878
that's how mine started. vibrate, no vibrate then vibration came back little by
little it got worst. it's hard to tell if the motor mounts are bad just by looking from under or from the top. anyway, it did fixed my vibration after replacing both mounts. just my 2 cents. goodluck.
Old Jul 19, 2008 | 07:31 PM
Musikmann's Avatar
2001 E320 RWD - Brilliant Silver/Ash: 100,000+
Engine vibration at idle that disappears once you start moving is a classic symptom of bad motor mounts. I have also seen suggestions to check your transmission mounts while you are at it.
Old Jul 19, 2008 | 11:28 PM
NOLA911's Avatar
g500, e500
Thanks guys. They should be in any day now
Old Jul 20, 2008 | 10:13 AM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Also check the high pressure hose coming out of the PS pump. It loops upward and if it touches the engine it will transmit vibration to the steering wheel.
