Light will not come on.
Old Jul 25, 2008 | 05:46 PM
step5pro's Avatar
1997 w210
Greetings All,
My rear roof passenger light will not come on regardless of the switch position. I removed and checked the bulb. It appears to be fine. All other lights work fine. Any suggestions. Thanks in advance.
Old Jul 25, 2008 | 08:25 PM
husk323's Avatar
Tesla Roadster Sport
check to see if you are getting power with the light switched on at the plug with a mm
Old Jul 25, 2008 | 09:48 PM
E-Klasse's Avatar
W205 C300
bad switch?
Old Jul 27, 2008 | 11:58 PM
step5pro's Avatar
1997 w210
I checked and there is definitely a current going to the dome light itself. The filament in the bulb is intact as well. I hoping the bulb is just faulty. Thats the cheapest fix.
Old Jul 28, 2008 | 12:25 AM
ohlord's Avatar
Dome
light 6411 bulb,if you checked power to the socket,switch the multi meter to ohms and test the bulb for continuity.
Old Jul 28, 2008 | 01:03 AM
step5pro's Avatar
1997 w210
No ohms were indicated.
Old Jul 28, 2008 | 02:19 AM
koskesh's Avatar
1997 E320
if you're getting 12 volts at the socket then the light bulb is bad.
Old Jul 28, 2008 | 01:32 PM
step5pro's Avatar
1997 w210
I put in a new bulb and PRESTO---LIGHT!!
Something so simple was out of my league without the help and knowledge of the various forums. I have the mechanical expertise of the "Valvoline Monkey".
Thanks to all replies.
