EGR-valve
Old Jul 28, 2008 | 03:11 PM
Semikolon's Avatar
2001 E220T CDI Avantgarde, 2002 E55T AMG
EGR-valve
Hi
After cleaning my inlet manifold and EGR-valve I wanted to get rid of EGR-functionality. Easier said than done.. By disconnecting the vacuumline and sealing the exhaust gas pipe the engine goes limp.
Is there another way to get rid of this ****ty exhaust gas recirculation? When driving without the EGR-valve connected I get better MPG (even when the car is not in limp mode) and less black exhaust, so I don't want it...
The engine is a 220CDI, but it's the same for all diesels with EGR-valve...
Thank you
Old Jul 28, 2008 | 09:44 PM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
Does it go into limp mode if you leave the vacuum line hooked up and just seal the exhaust line?
Old Jul 28, 2008 | 10:45 PM
ohlord's Avatar
tried
the old ball bearing trick?
Old Jul 28, 2008 | 11:05 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
Those EGR valves on the CDI's usually have a sensor that is tied into the ECU. Once it "sees" a disconnect, or if the valve doesn't open as designed, it will put the motor in limp home.
I guess the way the other replies claimed might be the way to go?
Old Jul 29, 2008 | 01:14 AM
Semikolon's Avatar
it goes limp by sealing the exhaust yes.
what is the ball bearing trick?
Old Jul 30, 2008 | 01:21 AM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
I've been looking into the same thing. Have you tried using a block off plate? I'm trying to find a EGR simulator but I cant seem to find one specifically for the MB.
Old Jul 30, 2008 | 02:36 AM
Semikolon's Avatar
as stated earlier, yes I have tried blocking the exhaust, which makes the engine go into limp mode because it doesn't get the amount of air it thinks it should.
Old Jul 30, 2008 | 02:47 AM
Semikolon's Avatar
The problem on the engine in question (220CDI/611.961) is that the EGR-valve is vacuum controlled and there are no sensors on it. The reason why the engine goes limp is because it doesn't get the right amount of air and the ECU thinks it's something wrong (or it understands I have done something illegal with the EGR).
So there are two theoretical solutions. Get the extra required air from elsewhere, or reprogram the ECU. An electronic EGR-simulator would not work.
So that leaves us to the first solution, get the extra required air from elsewhere.... How do we do this? By replacing the exhaust on the valve with an airfilter to suck clean air would not work because of the turbo, which will just press air out of that filter instead of the engine sucking air through the filter (I think)
Old Jul 30, 2008 | 12:34 PM
lynall's Avatar
E430 Avanrgarde
I reckon it knows the egr has a problem because when it tells the egr valve to open the inlet air temp/boost sensor does not see a rise in temperature in the inlet manifold.
Sounds logical?.
Your valve filter idea would not work.
Lynall
Old Jul 30, 2008 | 03:26 PM
Hirnbeiss's Avatar
No one in the US has a 220 Diesel, but I believe the M112/M113 operate with EGR valve position sensors (switch E 28/3). That would indicate that leaving the vacuum line hooked up to move the valve will still trigger a correct position signal for the EGR valve.
Plugging the exhaust line might then trigger a mixture-related check-engine light (a la the M104's of old), however.
Old Jul 31, 2008 | 03:42 AM
Semikolon's Avatar
Sounds logical?.
Lynall
I think both those sensors are placed before the valve, on a tube leading from the intercooler.
Old Jul 31, 2008 | 03:48 AM
Semikolon's Avatar
There are no sensors on the valve itself, only vacuum. So the reason why it goes into limp must be from one or more sensors inside the engine as there are no sensors between the valve and the inlet ports on the engine.
This will be the exact same for 270CDI (OM612.961) and 320CDI (OM613.961), I believe you have the 320CDI over in us?
I don't get a check engine light, or engine warning message in assyst, it just loses its power without any notice.
Old Aug 4, 2008 | 09:56 PM
Hirnbeiss's Avatar
The 320CDI came out in 05 on the W211, but it looks like DGITURBO has one in his ML. If it's not a valve position switch, can it be something with the vacuum transducer? Did you read out the code that caused it to into limp? Maybe the mixture is just way off for the throttle/rpm combo.
Most people advise against removing the EGR these days. Since it is usually closed at WOT and idle anyway, where's the big performance gain?
Old Aug 10, 2008 | 04:44 AM
Semikolon's Avatar
There's no performance gain, but the reason why I want it away is that the car runs smoother and uses less fuel when it's disconnected. Also there are no black smoke at all when disconnected. Now after a few weeks with full EGR pass through the car smokes so much that sometimes I can hardly see what's behind me.
But I think I have a solution...
I will have to modify the inlet pipe to the turbo with a new small intake that doesn't pass the MAF. This new inlet will have a valve controlled by the same controller that controls the EGR-valve. This way the engine will get more air than the MAF reports when the EGR-valve is supposed to be open.
Old Aug 12, 2008 | 05:57 PM
EdzBenz's Avatar
W210 W140
Please post a report of what you are attempting with the new inlet. I'd really like to see some pictures and a report of how it went. I took off my intake manifold last week and it was really dirty with soot and want my EGR disabled.
Old Aug 13, 2008 | 12:41 PM
Semikolon's Avatar
I'll update you on the situation if I decide to carry out this operation.
Old Aug 13, 2008 | 05:57 PM
EdzBenz's Avatar
W210 W140
Great. Thanks. I look forward to it.
Old Oct 21, 2012 | 10:13 PM
W210MB's Avatar
w210
Oil leak
I need help please.
Hello.
I have problems with the oil leak in the hose.How can come oil leak?Maybe from EGR or intercooler? But the flow of oil goes up to turbo Charger! Where is the problem here?
How come oil leak?Thanks.
My car is:MB 220CDI, w210. 2001 year.
Old Nov 13, 2012 | 02:17 PM
giuseppesalvato's Avatar
E220cdi avantgarde
Question
there is a solution using a couple of resistors and a diode wired into a circuit to fool the ecu into thinking the valve is operating. I believe a DIY has been put up to explain the method.
Last edited by giuseppesalvato; Nov 14, 2012 at 12:02 PM. Reason: changed the word sticky to DIY
Old Nov 14, 2012 | 03:41 PM
W210MB's Avatar
w210
Could you please be more clear on this explanation.Which Resistore, where lies resistori?Can you tell me where is the ECU in Mercedes?
Old Nov 15, 2012 | 01:51 PM
E220cdi avantgarde
Look at the DIY written by Images on the 11-5-2012.
Old Nov 15, 2012 | 02:18 PM
W210MB's Avatar
w210
Look at the DIY written by Images on the 11-5-2012.Where is the Image ?Can you help me to find it ?Please. <TABLE style="BORDER-TOP-WIDTH: 0px" class=tborder border=0 cellSpacing=1 cellPadding=4 width="100%" align=center><TBODY><TR title="Post 5433642" vAlign=top><TD class=alt2 width=125 align=center>giuseppesalvato</TD><TD class=alt1>Look at the DIY written by Images on the 11-5-2012. </TD></TR><TR><TD class=thead colSpan=2>Yesterday 03:41 PM</TD></TR></TBODY></TABLE><TABLE style="BORDER-TOP-WIDTH: 0px" class=tborder border=0 cellSpacing=1 cellPadding=4 width="100%" align=center><TBODY><TR title="Post 5433642" vAlign=top><TD class=alt2 width=125 align=center>giuseppesalvato</TD><TD class=alt1>Look at the DIY written by Images on the 11-5-2012. </TD></TR><TR><TD class=thead colSpan=2>Yesterday 03:41 PM</TD></TR></TBODY></TABLE>
Old Nov 18, 2012 | 01:06 PM
toby1's Avatar
W210 2002 E320 CDi Avantgarde
This may help: http://forums.mercedesclub.org.uk/sh...ad.php?t=68928
Old Nov 20, 2012 | 05:21 PM
W210MB's Avatar
w210
Hi.
Originally Posted by toby1
Toby1, thank you very much.I will try.Thanks a lot.
Old Nov 25, 2012 | 12:46 PM
nsolot's Avatar
1999 E320 1971 280SL
Is there a DIY to clean the EGR valve?
I've searched & searched, but can't locate one.
TIA
