Tire Size Question
I have a 2000 E320 with stock 16x7.5 alloy wheels and 215/55/16 tires. I just got some chrome 16x8 oem Mercedes wheels. What tire size should I buy. I am trying to keep it as stock as possible and I am trying to keep the speedometer as close and possible to actural speed.
You want to stay away from chrome anyway,they chip,rust,leak and are generally a pain in the .
what is the offset?
Anyways, I would still use 215/55/16. This size of tire can go on 7" or 8" rims.
Another option is 225/50/16 which may be almost an inch shorter in overall diameter.
Here is a link to compare tire specs.
LINK: http://www.tirerack.com/tires/Spec.j...e1=yes&place=3
225/45 is 46 revs more per mile that would be like underdrive.
215/50 you are off 30 revs per mile
Go with the 225/50 on an 8in rim it will hold a better sidewall,there is plenty of room for it and it will look and perform better.
