Brake rotor size
Let me tell you 316mm Rotor would not fuc**** fit into the 1997 w210 e420 , this is a fact now ! Even when you buy brake pads you will not find any brake pads that are sized for 316mm rotors, IT IS 300mm. So far i can safely say that all North American w210s up to 1999 have the 300mm Rotor size. Hope to save you
some time
Note: the Sept 1996 Road & Track article claiming 12.4"/11.4" (315mm/290mm) is also incorrect for the fronts.
