97 E320 need help with lights
Old Aug 13, 2008 | 04:13 PM
frust's Avatar
Lightbulb 97 E320 need help with lights
Right head lights, right tail lights and right brake lights not working. Left side works fine. All bulbs are all good. The 7.5A fuse for the right tail light (#7 in the fuse box by steering wheel) blows up every time it is replaced. Anybody had experience with similar problem? is there a common fix?
If not where could I find the wiring diagrams for 97 E320 so I can start debugging to find the short or whatever the problem is.
Old Aug 13, 2008 | 04:30 PM
ohlord's Avatar
Look
for corrosion or a bad ground wire in the rear brake socket.
