Third Brake light and Park Lights Not working
Old Sep 9, 2008 | 03:25 PM
tbDallas's Avatar
'97 e320, '06 Corvette Z06, '71 Chevelle SS, '02 Ford F250
Is there a connection between the two? Ive checked all of the fuses and they seem to be all good. Ive noticed that not only does my 3rd brake light not work all of a sudden, but the park(?) lights (the lights that come on when you switch headlight switch to the left, or to the right and pull out two clicks) no longer work. Is there a specific fuse number for this (i don"t have an owners manual) or something else that controls them? No all that worried about the park lights, but would really like to get the 3rd brake light working again. Please advise.
Thanks,
tbDallas
97 e320
Old Sep 9, 2008 | 04:41 PM
ruffrob's Avatar
2010 Charcoal Grey E350 Coupe
TB,do a search on the subject in this forum. I had the same model you have,and that issue drove me nuts. I wound up changing the whole tail light assembly,and while my lights worked,the message on my dashboard refused to go away. As you can see ,I changed my car and it's a real relief not having to deal with that issue. But like I said,do a search,you may uncover a viable solution that wasn't available when I was dealing with it....Good Luck
