Sparkplugs for a E320.
. What plugs are good in this car? Ive heard certain plugs are prone to misfire and others are godly so point me in the right direction.On a install/removal note, I dont think ive ever seen a european car with such an easy plug removal process as the mercedes M104 powered ones
Keep pushing on,you will get there
you might also want to check out a ngk BKR6ES I think it is about 100 degrees cooler.
visit the w124 forum and find out what some of those old m104 turbo kits used.
the bosch copper is supposed to be the king plug in the m104,but I forget which way their numbers run to the cold side.So you could also check bosch usa.
Also I searched up thoes plugs you told me and it seems NGK raises the number on the plug the colder it gets and bosch lowers it.
Thanks alot for the plug numbers man, life saver. Probably an engine saver too since im so impatient.
