Condensation in Composite Lamps. '97 E300
Anyone know the cause for the leak on the composite lamps? Only seem to appear when under very hard rain or car wash. At least it clears up when the bulbs is turned on, but raises concern when I want to upgrade to H.I.D. lamps. I'm not interested in the replacing the entire headlamp assemblies.
Originally posted by E55 KEV
The bad news is that when water or moisture gets into the W210 headlamp it has to be replaced.
It can be re-sealed. The seal of the lens and the housing is secured by some silicone. Just make sure you don't have any cracks in the housing and make sure the o-rings of the blinker bulb socket is not worn out. Basically, you have to check all the areas for possible leaks. My advice is to take out the assembly before you do any trouble shooting.
But like E55 KEV, it's probably better to replace the assembly entirely and upgrade to a HID diffusion pattern lens. I believe Bekkers sells them.
W210 (1996 E320) white
One of mine had some water in it when I bought the car; the cause was a wire caught in the access cover seal allowing it to admit water. I took the cover off before a 45 minute drive at night (so the hot lights would help the h2o evaporate) then replaced it, haven't had problems since.
-tom
-tom
2016 GLE63s / 2016 E63s / 2002 E55
Originally posted by michakaveli
Why smust they be replaced? I know on my Dodge Spirit lamps I just resiliconed the seal between the lamps and the lense and problem solved. I was hoping for the same method to be implied here... hmmmm
