OM606 question. Broken CCV part
to the original poster.... I wouldn't drive it at all. worst case that plastic that broke off can break apart into smaller pieces and block an oil passage. catostrophic potential...
There is a bright side here. You could leave it in. Yes the rubber will break down over time, but the place where it is located is totally enclosed. It really isn't going anywhere. In fact if you take the valve cover off, the tray which is holding the rubber remains of this elbow is RIVETED in place, argh.
Best choice is to remove the offending rubber so that you will sleep better at night.
