Door Issue "HELP"
Old Oct 14, 2008 | 02:51 PM
mike430sport's Avatar
2000 E430 Sport
Door Issue "HELP"
I think my lock is bad, on rear passanger side. I had my window regulator changed and now the lock is acting up. The wire that is connected to the door handle will not retract. The wire is pulled in the open position and stuck that way. The door could be opened and closed from outsided. Sometimes it gets stuck closed. Sometimes the door lock won't grab, when closing. When that happens I can't close door till I pull the wire hard a few times. I keep the door panel off till I find a fix. PLEASE HELP
Old Oct 14, 2008 | 04:19 PM
HOWSER's Avatar
2016 Z06/Z07, 2017 AMG GT
Take the panel off and connect the end of the door release "wire" to the holder (for a lack of a better word). It will be located about 2 inches from the metal "c" hook on the door. This will provide tension.
Old Oct 15, 2008 | 09:17 PM
2000 E430 Sport
I don't know what you mean
Old Oct 15, 2008 | 09:40 PM
Hirnbeiss's Avatar
'99 E430, '05 ML500, '15 GLK350
I think he means make sure the cable is pushed into the retaining clip.
Old Oct 16, 2008 | 10:42 AM
HOWSER's Avatar
This is what "he" means.
Old Oct 16, 2008 | 04:17 PM
2000 E430 Sport
here is the pic
I don't see the clip
Old Oct 16, 2008 | 05:05 PM
Hirnbeiss's Avatar
"we" can't see the picture, but there is a little clip for the bowden cable to snap into
Old Oct 17, 2008 | 07:50 AM
HOWSER's Avatar
The clip is on the door panel itself, not the door. It's a small squarish and black located about 2-3 inches from where the cable connects to the inside handle. Hook the end of the door cable in the handle, pull in the cable sheathing to expose more of the cable itself and place the cable into the clip causing the sheathing to rest in the clip. This will provide tension to the cable.
Old Oct 17, 2008 | 06:42 PM
2000 E430 Sport
ok I see the clip I will try it out
Thanx
