Help! code P0455 - P0300 - P0304
Check engine lights have been on for two months but the car was running fine
Could not find problem
Today it got down to low 60s in Florida and the car started to back fire on take off
I have been only getting P0455 and a flashing fuel light which clears itself
Now I am getting P0300 and P0304 with a slight backfire on take off at times
Help!
Please suggest course of action
other two codes:
p0304 that is code for your cylinder #4 misfire detected (could be spark plug )
p 0300 muliple cylinder misfire detected (happend to me once on a diferent car when I was leaning engine)
it may help you to diagnose problem
regards
they will meet their own internet price if you take the online ad for item #94169
handy little hhs to have for the do it your self mechanic,reads codes,erases reads i/m readiness for smog etc.
once cleared see what comes back.Then we go from there checking for loose or broken evap lines to the charcoal canister,purge valve etc.
you are not in the habit of topping up your fuel tank are you?
ohlord
last just incase it is a seperate issue check plug 4 plug connector,M104 engines have a problem with those crappy connectors.that is why you always replace them when you do the plugs.OEM plugs,none of those multi tip plugs on that old school engine.
Still check engine light - still flashing fuels light occasionally
I have replaced ignition coild three different times over 100K miles
I unfortunately do not know which they were but it seems the issue is with four
Recently replaced plugs and wire when I di last coil 5000k ago
Seems dampness and tempeture drop cause more issues
Car is definitely running as a misfire
Did not clean purge valve enen though I have purchased the cleaner previously reccomeneded
I was afraid to loose the car all together
Low cash - only car
I have not replaced the fuel filter or air filter recently
What is the normal service cycle on these items
PS yes I purchased the computer you reccomended some time ago
ohlord
I will replace the ignition coil and air filter but I don't know if fuel filter could effect
Please see last post as well
