Third Brake Light repair on '97
Old Nov 6, 2008 | 06:28 PM
sct1965's Avatar
2004 E320 4matic
Third brake light repair
I failed inspection because my third brake light was out. I changed the bulb and it worked for a few days and then went out again. I took a multi-meter and tested the bulb and it was still good, so I knew the problem was with the fixture. I finally figured out how to remove the fixture and I found that one of the contacts was burned and pitted. As a temporary fix to pass inspection I cleaned the contact and bent it so it would make better contact with the base plate. I had some time today so I took everything apart and did a better job with the repair. This time I removed the bad contact and put a blob of solder on the pitted area and filed it down so that it would make a better cleaner contact with the base plate. The attached photos show some of the steps in the repair process.
Just a note. I never got any lamp out message, so I didn't know it was out until I failed inspection
Attached Thumbnails Third Brake Light repair on '97-brake-light-1.jpg   Third Brake Light repair on '97-brake-light-2.jpg   Third Brake Light repair on '97-brake-light-3.jpg   Third Brake Light repair on '97-brake-light-4.jpg   Third Brake Light repair on '97-brake-light-5.jpg
Old Nov 6, 2008 | 11:37 PM
armanchosbenz's Avatar
06 e350 4matic/2000 e320 4matic wagon
I had the same problem...i think all 96-97's have this problem...i think the 98 model got the different upgraded third brake light and the problem was corrected...when i tried to remove the plastic cover it shattered into small pieces...it took me 3 months to find another one on ebay (brown)...when i got the one from e bay,it also had one of the metal tabs burned...so finally i got fed up and filed it clean and reinstalled it...so far it's working ok
