brakes question
Old Nov 7, 2008 | 01:56 PM
dylokjai's Avatar
00_e430_sport
brakes question
I was attempting to replace my front brake pad i removed the 2 allen wrench bolts anti rattle spring thing and a star type screw bolt thing for the sensor but the caliper wont come off need some help asap thanks reason asking is i think i might be forgeting something and i dont want to damage any parts
Old Nov 7, 2008 | 02:06 PM
RobertG's Avatar
things with and without wheels
with the key off disconnect the abs asr module
Old Nov 7, 2008 | 02:20 PM
dylokjai's Avatar
00_e430_sport
where is the abs asr module? and what doea that module got to do with not able to remove the caliper?
Old Nov 7, 2008 | 04:23 PM
ohlord's Avatar
Did you
remove the caliper mounting bolt from the back side of the caliper?
Double check your work,and it is always a good idea to only do one side at a time so you have a comparison to look at if you are winging it without a WIS or diy .You will figure it out and go DOH
Old Nov 7, 2008 | 04:57 PM
dylokjai's Avatar
00_e430_sport
in the DIY section i printed out in BenzWorld same as the DIY on this forum but pdf file it say i do not have to remove but loosen only the mounting bolts from the back side if im not changing the rotors so i guess i'll just take those mounting bolts off and see whta happen
Thanks ohlord....
Old Nov 7, 2008 | 06:01 PM
RobertG's Avatar
It's in the engine compartment driver's side wheel well, you'll see brake lines and a module. your vehicle is equipped with asr , it can apply brakes without you hitting a brake pedal so play it safe and key not in the ignition and disconnect the module. Try prying the brake pads a little to colapse the caliper then it should give you enough clearance to lift the caliper off .
If you want a more complete version of this procedure use the search in the w210 section someone did a very nice writeup of it.
Old Nov 7, 2008 | 06:02 PM
RobertG's Avatar
this is the link
https://mbworld.org/forums/e-class-w210/107227-okay-brake-job.html
Old Nov 7, 2008 | 08:00 PM
dylokjai's Avatar
00_e430_sport
thanks you RobertG and Ohlord but i finally figured it out lol
