Flashing gas light P0455
Old Nov 8, 2008 | 04:25 PM
MB Enthusiast's Avatar
1997 E 320 - 2000 S500
E320 1997
Cleared the P0304 and P0300 codes - Inginition coil on 4
Still have intermitant flshing gas light and eventually CEL P0455
I never top off gas
I have replaced gas cap with OEM cap which does look different that the original but seem correct and tight
I have cleaned prurge valve and hose with the correct CRC product
Used mechanic stethoscope and valve seems to be working perfectly
Engine seems to be running smooth but I want to clear issue
any other ideas
Old Nov 8, 2008 | 05:38 PM
ohlord's Avatar
Check all
vacuum lines,check lines going to charcoal canister.Did you get the cap from the dealer?
Smoke test,next
Old Nov 11, 2008 | 02:13 PM
Vacuum Lines
Are the vacuum lines the lines from two lines on the purge valve?
Yes OEM cap but you can not get the exact looking cap that was previously on car
It is flatter now
Could it be the gas filter - Gas filter is way over do
I did run a tank with seafoam 6 months ago but I need to change filter
I have the part and will do it next week
If I need smoke test who will do it and how much will it cost
Where would you epect to see the leak in a smoke test?
Old Nov 11, 2008 | 02:17 PM
Gas cap looks like this
http://www.autohausaz.com/search/ima...1404700005.jpg
1404700005
Old Nov 11, 2008 | 04:13 PM
ohlord's Avatar
Any of the
myriad of lines from the tank to the purge valve.Someplace in the evap system air is getting in and fumes are getting out.And it monitors that and says no no no.
Check the lines at the canister,they dry out and break.
Was it a dealer cap?Your local smog station may test a cap for free.
Old Nov 11, 2008 | 06:25 PM
Cap was from dealer
Can you provide a site that I can see what the current version of my gas cap should look like
1997 E320
Old Nov 11, 2008 | 07:14 PM
lkchris's Avatar
'10 CL550, '12 GL550
What's a "gas light?"
The light shaped like a gas pump simply indicates low fuel.
Old Nov 11, 2008 | 10:04 PM
ohlord's Avatar
Gross
leak .040inch or bigger is indicated by flashing gas light.Happens before a code is set.That is what he means
Bad cap,broken evap line,leak in something,he needs to find.
flip the gasket over on the new fuel cap you got from autohausaz.com.Get underneath and look for loose hoses on the evap canister.
you can't buy a smoke machine they are $$$
http://www.denlorstools.com/home/dt1...em_tester.html
find a shop with one if you can't find the leak.You won't pass smog and the light will drive you nutty.
This is a diagram of the M112 and M113 system very similar to your M104 with some minor changes,but this is the path you need to search.
maybe shucks or autozone rents them
http://www.redlinedetection.com/
Old Nov 13, 2008 | 12:26 PM
ohlord's Avatar
Did you fix it
yet?
The gross leak P0455 also set the misfire code you cleared so keep us posted
Old Nov 13, 2008 | 10:09 PM
No access to smoke test
I don't have access to a lift or smoke machine/testing site
I will have to put the car up on ramps and see if I can inspect vacuum hoses
I was hoping for an esier answer
Old Nov 14, 2008 | 02:52 AM
ohlord's Avatar
Fuel cap
would be the easier anwser.Seeing as you ruled that out,hunting down a 4/100ths hole is up next
Swap a cap with someone with a known good cap.Look at the hoses to the charcoal canister and valve and proceed forward from there.
Old Oct 29, 2009 | 05:54 PM
colliegrey's Avatar
E420
I found out that regular gas is what causing the problem! I started using premium gas and one gas treatment and my gas light stop flashing after about 20 miles and my check engine light went off.[IMG]file:///C:/DOCUME%7E1/HOMEPC%7E1/LOCALS%7E1/Temp/moz-screenshot-4.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/HOMEPC%7E1/LOCALS%7E1/Temp/moz-screenshot-2.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/HOMEPC%7E1/LOCALS%7E1/Temp/moz-screenshot-3.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/HOMEPC%7E1/LOCALS%7E1/Temp/moz-screenshot-1.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/HOMEPC%7E1/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
