cold weather
Old Nov 22, 2008 | 09:25 AM
deno's Avatar
02 E430 4matic 07 E550 4matic
cold weather
Has anyone had issues with locks not working everytime its 35 degrees or lower.This is my second winter and everytime it gets could my remote locks don't work, my car is E430 4matic.
Old Nov 22, 2008 | 03:14 PM
ohlord's Avatar
Check that
the ir receiver in the door is clean and polished ,same with the end of the key.Have you replaced the key batteries,cold weather can run them down.Check you pse is not wet.
Old Nov 22, 2008 | 04:16 PM
deno's Avatar
More help
Thanks Olord, One other question, my warnning sings came on today abs and the other ones like when the break switch is no good, anyway I replaced the switch today and no fix is there something else I need to do, this happened last year and it was easy fix but this time nothing,
Thanks for any kind of info,
its great to have this forum.
Old Nov 22, 2008 | 08:42 PM
ohlord's Avatar
Check
battery and alternator output,below 11 volts triggers those warnings and also corrosion at the brake light sockets.
pm'd you about the short jumper wire to test a bad brake switch.
