Diesel fuel line path, part identification
In another post a link was given to me showing a flow path, here it is;
http://bp3.blogger.com/_p71v9ofBM6w/...h/fuelflow.JPG
I have just found that the number 1 line is wet around the block coming from the engine going to the prefilter. Previously, and since I have owner the car I have seen nothing. I guess that it has just reached the point where it's now visible? Using the illustration's indicated direction of flow, and looking up a replacement line. Is the block where the number one line connects a thermostat?
The sites that I looked up the part, discribe the lines in order of fuel direction. So, this line I believe is the one referred to as "thermostat to prefilter (strainer)". Is this correct?
Please reply
Lowflyingbird
Heats the fuel when/if/as needed.
The short line connecting to the thermo is difficult to snap down in place and seal. Try removing it and reinstalling.
Push white horseshoe clip in tight, pull fuel line, examine oring, if oblong rather than round replace it, pull white clip back out so is loose and floopy, put fuel line in place, use 12" screwdrriver on top of line to get better leverage and push/lever down until you hear or feel TWO clicks. If that doesnt do it try putting some silicone grease on the oring and seating it again.
Hopefully all goes well,
Thank you again
Lowflyingbird
In the future you might want to get some viton orings. They hold up better/longer. MB uses buna rubber. I helped a fellow from another forum with the sizes and he's put a kit together for the 606. See fryerpower.com
I have no affiliation.
The HBNR rings are primarily for air conditioning, but I've been told they hold up to alot of conditions.
Lowflyingbird
Lowflyingbird
